watched Spiderman No Way Home (full remux including DV layer) last night using client version 8.31.1.31487 and had no issues with TrueHD audio.
Yeah the reports on spider man donāt make sense because it has no branching stuff.
They absolutely make sense, because the issue being discussed in this thread has nothing to do with seamless branching.
Some titles have issues due to seamless branching and some titles have issues due to a regression with Plex app.
Agreed, but the issue raised here affects any and all TrueHD/Atmos titles. Itās the regression thatās being discussed here, which now seems to be fixed, while the seamless branch issue is very likely not fixed.
Personally, I havenāt encountered the reported issues (in this thread) regarding Dolby TrueHD bitstreaming/passthrough. However, I am not disputing that this Plex app regression does exists with certain AV setups. Itās been difficult for me to help anyone when I havenāt been able to replicate it myself.
As I stated earlier, the resolution for this regression is a WIP with the developer. I have yet to update the public channel app v8.30.2.31202 on my production units. Google hasnāt offered v8.31.1.31487 and I havenāt bothered to side load it with adb.
Makes sense that you havenāt encountered it, because it was a regression in the 8.31.0.x builds.
Anyway, I just thought the thread was getting derailed by all the talk about seamless branching and MakeMKV.
Hopefully, the final 8.31.1.x will finally make its way to us today ![]()
All I can say is, I have the alpha channel app installed in parallel with the public channel app on both of my 2019 Shield Pros I use as production. It is even more painful than the issues reported here for the beta channel app. The developer is working diligently to solve the issues I have reported.
Yeah, that might be my fault⦠Sorry yaāll ![]()
I only have so much time in my life to allocate for volunteer alpha and beta testing. Like you guys, I want a no-holds-barred experience with the Nvidia Shield Pro. For now it is the only platform that has the potential to do everything.
I split a lot of my free time between testing with Plex and testing with Nvidia to ensure all video and audio codecs work properly. When it comes to AV setup, I am OCD and strive for perfection. My AV setup is entering into the $100,000 range so I donāt want to compromise because of deficiencies and regressions in the source player.
It is easy to get caught up in the passion of AV enthusiasm and forget that using alpha and beta applications come with no guarantee of proper functionality. I can not speak for the Plex staff as to why you all did not get a response to this thread. Rest assured though that I am always championing for full video and audio codec functionality with the dev(s) that work on the AndroidTV appāparticularly for the Shield Pro.
>> And I get funny looks from my family and friends when I tell them Iāve hit the Ā£7000 mark, but thatās just another level AND some !! lol
Maybe I should clarify. Iām not saying it doesnāt make sense for people to make posts about it, Iām just saying it doesnāt make sense like I donāt understand it. Because I have watched this same spider man remux about four times now and I have not been able to see what you are talking about. Thatās all I was saying. No need to get your panties in a twist especially since it sounds like your issue has actually been fixed while this seamless branching thing has been going on way longer.
Youāre out of line here, bud, and clearly this thread is not for you.
Thatās the nature of software bugs right? Logic is broken thus a function becomes defunct.
If your prior action still holds true, you wouldnāt be seeing an issue with your remux.
just wanna chime in as another user with really, really bad hitching in the current android tv beta (nvidia shield pro) on personal bluray and uhd rips, and flawless playback with the current non-beta player. (wired gigabit ethernet, no transcoding)
low bitrate content seems to play completely fine in the current beta
I believe there is a memory leak at the root of it all.
Much like I suggested quite some time agoā¦
Put it this way, the buffer hits 512.00MB and then has to flush thus a drop in frames or pauses. It happens every time I observe the stats of the player.
Yeah thatās actually correct I did roll back so I suppose I never saw this bug regression thing.
