Nvidia Shield not playing some HEVC content anymore
Server Version#: 1.32.5.7349 Windows Server 2016
Player Version#: 9.30.0.3604 NVidia Shield Client
It plays h264 just fine. Smaller HEVC files also play fine. However, movies that once played ok, not just get a spinning circle in the middle of a blank black screen. Plays / transcodes on a web page just fine as well. It just doesn’t play on Nvidia Shield anymore.
Plex server status shows nothing on the dashboard, so it doesn’t even seem to have the request to play.
Any suggestions where to look (logs / status) to determine what is going on?
Here are the details of a movie that doesn’t play from the file info:
Media
  • Duration 1:57:07
  • Bitrate 691 kbps
  • Width 720
  • Height 360
  • Aspect Ratio 2.35
  • Video Resolution SD
  • Container MKV
  • Video Frame Rate 24p
  • Video Profile main
Part
  • Duration 1:57:07
  • File Split.mkv
  • Size 581.40 MB
  • Container MKV
  • Codec HEVC
  • Bitrate 239 kbps
  • Anamorphic true
  • Bit Depth 8
  • Chroma Location left
  • Chroma Subsampling 4:2:0
  • Coded Height 360
  • Coded Width 720
  • Color Primaries smpte170m
  • Color Range tv
  • Color Space smpte170m
  • Color Trc bt709
  • Frame Rate 23.976 fps
  • Height 360
  • Level 3.0
  • Pixel Aspect Ratio 32:27
  • Profile main
  • Ref Frames 1
  • Width 720
  • Display Title SD (HEVC Main)
  • Extended Display Title SD (HEVC Main)
  • Codec AC3
  • Channels 6
  • Bitrate 448 kbps
  • Language English
  • Language Tag en
  • Audio Channel Layout 5.1(side)
  • Sampling Rate 48000 Hz
  • Title Surround
  • Display Title English (AC3 5.1)
  • Extended Display Title Surround (English AC3 5.1)
  • Codec VOBSUB
  • Bitrate 4 kbps
  • Language English
  • Language Tag en
  • Display Title English (VOBSUB)
  • Extended Display Title English (VOBSUB)
I too have noticed that the Shield will barf on some HEVC files. the problem came and went a few times over the years, presumably due to intermittent issues with the Shield client.
When that happens I pick “convert automatically” and playback resumes.
Thanks for the note. Where is the “convert automatically” option?
If you go into the playback settings you should see it in there somewhere. The other option is to show all the settings, and you can pick a specific resolution/bitrate target if you want. Basically… If you force transcoding, it will play.
