i’m using Plex 0.9.3.4 an install the OFDB plugin.
I start a new section with only one film (Avatar) (German) for a tryout.
But no metadatas recieved an no cover or anythin else.
Could you please help me.
ShortyLE
Hi had the same experience with this scrapper. could it be that it is broken and/or the api of the web service has changed ?
Did you set the language to "Deutsch" when you created your movie section?
OFDB movie rating is not working for most non-english movies.
I have the Plex movie library set to German.
I have OFDB metadata agent as top of my list of metadata agents.
I have activated the option to get movie rating from ODFB.
Movie example:
The Invincibles (1994) / Die Sieger (1994)
I get movie description, I get FSK rating, I do not get any movie rating (field empty; shown as zero from within edit data dialog of Plex web; empty field export with Plex2csv.
Could somebody please test / verify / fix this?
Thx.
@rossinior said:
OFDB movie rating is not working for most non-english movies.I have the Plex movie library set to German.
I have activated the option to get movie rating from ODFB.Movie example:
The Invincibles (1994) / Die Sieger (1994)I get movie description, I get FSK rating, I do not get any movie rating (field empty; shown as zero from within edit data dialog of Plex web; empty field export with Plex2csv.
Thx.
This has been fixed in f26d490
Hello!
i started an article that i have a meta data error. now i was told that the error is probably caused by ofdb.
the link to the bug message.
[BUG] age restriction meta data update
i also want to see the screenshot of the ideal setting only the link doesn’t work anymore.
Where can one find the latest version of the OFDB plugin?
From looking around, it seems to me that the 4…7 year old version on https://github.com/KKCB/OFDB.bundle is the one to use. Is that really true?
I have tried to install this Version of OFDB.bundle:
But it don’t work with the aktual Version of Plex.
Can anybody help me?
