Offline Live TV - Buggy
Please give some testing to Live TV when connectivity to the Internet is down. Had a recent event with the ISP that caused an extended outage. Went to use the Plex TV Live TV and it was very buggy with sometimes starting up, sometimes crashing.
That is something that we do test already. Could you be a bit more specific about what issues you saw, please? :slight_smile:
Sweet! - Love the testing, and the app. Then it must have been something on my end. As I try tuning in live TV, there were a couple of times where it could not create recording. I attempted to load 4 times before it did load. The first it started, then went into a little bit of crashing (sorry for not capturing images). Then the second and third attempt had the failed to create recording, then the last one was successful for a while. I was away when the last attempt started having issues.
Version 1.13.2.5154
Setup: Apple TV 4th gen (I think, the first one that supported apps) with minimum amount of memory Plex running on Centos VM on VMware server instance HDHomeRun CONNECT TV Tuner
If you see this again, could you grab some logs from the server, please? :slight_smile:
