Offline synced media on mobile Android app not playing on chromecast
I found the fix. At the right bottom corner of the player are three dots. Select this, and then Playback Settings. When I selected Convert Automatically, then connected to Chromecast, and then started playing the movie, it worked.
“At the right bottom corner of the player are three dots. Select this, and then Playback Settings. When I selected Convert Automatically, then connected to Chromecast, and then started playing the movie, it worked”
I am on latest Plex client 8.4.0.19279, galaxy note 9 on android. I don’t get “convert automatically” on playback settings (at least not when playing a sync’d file).
The workaround I used last year was to roll back to a very old client (can’t remember but was 7.17.4 I think) on my old phone, which still worked ok. Unfortunately, I was naive enough to presume Plex would’ve fixed this by now, so I have gone on holiday with my current phone & current plex client, with several GB of sync’d media and no backup :frowning:
The other workaround mentioned in this thread (either use external player in plex options, or browse externally to the plex file on local storage and play it from another app that sullorts casting) no longer works for me, either: the former gives errors on both VLC and bubblepnp when trying to cast; the latter no longer works because (unrooted) the android/data/com.plexapp.android/files folder shows as empty, and I can’t find my GB’s of sync’d content anywhere else on local storage.
So, anyone who is unrooted on android, and who can successfully either play sync’d media to external player and cast that successfully, OR who can locate where the underlying files are on local storage, could you please post an idiot proof guide?
Just to add: I just tested with 7.17.4 again - still installs OK and connects to plex server, but it no longer allows casting of synced files, you just get same gray screen as for current client.
Oh well. At least I have brought a usb/HDMI hub with me this time, so I can at least use Samsung DEX to get my video on the big screen. Total PITA though.
In exactly the same situation. This used to be such a great feature and I can’t find any workaround that actually works with casting sync’d media on andriod
Can’t believe this is still broken. It isn’t just for Chromecast, clearly it’s inherent to the plex app on mobile device as a “server”, seeing as it doesn’t work on Chromecast, my Apple TV or my Roku Premier. This is such an important feature to have on board for me. Please sort this out!
Still Broken
 Just posting so this topic doesn’t close.
Please fix this.
for me it’s just music files , no problems with video, just music, buying the plex pass didn’t do anything for me.
I seem to have the same issue. Have been using Plex to cast to Chromecast for several years and really impressed. In Feb 2020 casting from any android device now results in “ready to cast” screen on the chromecast device and the android app crashes with “App has stopped working” error message. Casting frommy PC to Chromecast is still working fine but all my andoid devices result in not casting and the same crash “app has stopped working” message and frozen screen.
I just tried it and it worked. Local sync’d video content cast to a new Google Chromecast with Google TV. Plex for Android version 8.16.2.24953.
Anybody else tried recently?
Casting of local sync’d video working to Chromecast Ultra. Took server offline to confirm, this looks like a fix to me. Can anybody else confirm?
