On deck broken
Server Version#:
Since the last server upgrade both my Nvidia shields no longer works with the ON DECK, nothing is put on there after watching a series, is this another bug
Do you have more than one TV library?
With the latest update to the Android TV app (not the beta version) I had to reset the home page and customization for “On Deck” to work. In my case, I think it was because I have two TV libraries, and I had set it to “Manually Manage” rather than “Manage Automatically” Having the app Automatically Manage the home page gave me back a functional On Deck
I don’t know if it’s server or app, but something doesn’t work right.
Reported it here :
Hi
Just the one . pcs are fine and it shows them as they should be but both the NVidia shields seem wrong, ipad and iphone are ok as well
I’m pretty sure the app update broke something in On Deck. I would try resetting the home page customization (probably to automatically manage) It was the only way On Deck items showed up for me. On deck did work in other apps for me too, just broken in Android TV.
thanks ill give it a go
many thanks that did it
I’ve got this now too, it’s pretty frustrating since I’ve got several shows on the go and have to dig around in my library every time there’s a new episode. Automatic management gets it back but I’m hoping for an actual fix soon.
Getting sick of bugs, if u go for auto I get 4 recent tv lines , 5 recent movie lines, when watching a series I have to come out of the series to select the next one, numerous other bugs, fix these things in stead of releasing other add ons.
Automatically manage did it for me as well.
Now I have On Deck back.
Thanks!
