On Linux moving my plexmediaserver/Application data directory
Server Version#: plexmediaserver_1.40.5.8854-f36c552fd_amd64.deb
I was previously running linux mint 20. The Application Data folder outgrew my root partition so I moved it to a raid 5 array and created a link from the new location. This was working fine for the last two - three years. I finally decided to upgrade to the latest LTS version of 22. I was already running the latest plex package on my mint 20 system.
I upgraded everything to mint 22, downloaded the latest plex server package and installed it. This works fine. As soon as I create the link to my original Application Data folder, plex refuses to start and throws permission errors.
I found that on my new system the plex user:group was different than my old system so I did a recursive Chown to correct it. I’ve checked the permissions and they all seem correct. I went back over the permission of any parent folders and corrected anything that looked off. I also tried using the /etc/systemd/system/plexmediaserver.service.d/override.conf to simply set the location of the new folder.
journalctl -b output shows:
Blockquote
Aug 18 12:56:54 MINT-System-File-Server Plex Media Server[11922]: libc++abi: terminating with uncaught exception of type boost::filesystem::filesystem_error: boost::filesystem::create_directories: Permission denied [system:13]: > “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache”, , “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache”
Aug 18 12:56:54 MINT-System-File-Server systemd[1]: Started systemd-coredump@6-11933-0.service - Process Core Dump (PID 11933/UID 0).
Aug 18 12:56:54 MINT-System-File-Server systemd-coredump[11934]: [🡕] Process 11922 (Plex Media Serv) of user 997 dumped core.
                                                             Module libgcompat.so.0 without build-id.
                                                             Module ld-musl-x86_64.so.1 without build-id.
                                                             Module libc++.so.2 without build-id.
                                                             Stack trace of thread 11922:
                                                             #0  0x00007f97b434bf80 setjmp (ld-musl-x86_64.so.1 + 0x82f80)
                                                             #1  0x00007f97b3d51187 n/a (Plex Media Server + 0xf51187)
                                                             #2  0x00007f97b3c7bd69 n/a (Plex Media Server + 0xe7bd69)
                                                             #3  0x00007f97b3e959a0 n/a (Plex Media Server + 0x10959a0)
                                                             #4  0x00007f97b431ba62 n/a (ld-musl-x86_64.so.1 + 0x52a62)
                                                             ELF object binary architecture: AMD x86-64
Aug 18 12:56:54 MINT-System-File-Server systemd[1]: systemd-coredump@6-11933-0.service: Deactivated successfully.
Aug 18 12:56:54 MINT-System-File-Server systemd[1]: plexmediaserver.service: Main process exited, code=dumped, status=6/ABRT
Aug 18 12:56:54 MINT-System-File-Server systemd[1]: plexmediaserver.service: Failed with result ‘core-dump’.
Blockquote
I understand from this that it still has to be permissions issue but I can’t seem to find the issue.
Any help appreciated.
Mint not supported.
Application folder needs to be a local disk.
it is a local disk. and it worked previously.
Don’t use a link.
Plex Linux Tips: Customizing your Plex configuration on systemd based systems
Also: Can't upgrade past 1.40.2.8395 - #5 by ChuckPa
Also, Be advised, MINT is not supported nor has it been stable as a Plex server.
While it’s a good desktop, it has proven itself unstable when subjected to the load of media server.
Honestly. I’ve been using linux for close to 30 years. Started on redhat. I’ve used suse, gentoo, mandrake,mandriva, peanut, etc.
I have supported linux, bsd, hpux, aix and mac server professionally as a system admin. And although I’m more fond of rpm based systems there is nothing wrong with mint. I just told you I’ve been running plex on mint for 3 years with no issues.
You guys are unbelievable.
I fixed it myself. I would prefer a better solution but for now I opened up some of the permissions on some of the parent folders. Bam working,.
I’ve only ever asked for something a couple times on these forums but each time it makes me wonder why I paid for a plex pass.
in the future instead of trying to figure out how not to support your product try being helpfull.
thank you for your helpful response.
Linux has changed.
  1. /etc/default was the old method until systemd became standard in 2020.
  2. Systemd allows customization in /etc/systemd/system/servicename.service.d/override.conf
I’ve been using Unix since the 80’s and started with Linux when it came out in 1998.
Plex runs as its own non-privileged user.
Giving PMS free reign on a machine isn’t always the wisest thing.
There are many users who want PMS constrained so that’s why it it’s default is constrained.
You can customize the config (in systemd) to be as unconstrained as you wish as well as move PMS’s AppSuppDir to wherever you want.
(That’s how I set it up)
As for Mint, I am relaying to you what our experiences are.
If Mint were a vetted OS, it would be listed.
For reference: There is a Linux Tips section here in the forum to show you the most common tasks.
