One channel will not tune on AppleTV
Just one channel will not work on my AppleTV. It works perfectly on all other channels but as soon as I got to this one channel it says “recording cancelled” or it just hangs there. It’s not the antenna as it comes in perfectly on HdHomeRun. It seems to only be in Plex. Any suggestions?
@Disguysj Can you record items from this channel? Or does the channel work in other clients?
It seems to record that channel fine, but watching it live is another story. The channel works perfectly in HDhomeRun’s own client.
@Disguysj Sorry, I wasn’t clear there. I meant in any other Plex client. Does it work on iOS, or in Web or Plex Media Player? :slight_smile:
I ended up deleting the DVR all together and restarted. The channel now works fine. Thank you anyway! :slight_smile:
