Hello All…
Below tool helped me to fix all PLEX IMDB ratings. I was very frustrated that ratings in my PLEX content all over the place and not really updating correctly as per agent scanning settings.
Below little beauly fixed all within few min. Note that I am not a Docker expert and used the available GUI.
It was bit challenging to use fix the correct paths in MAC as my PMS is in MAC and hope below will help others as well.
Big thanks to the developer on this tool. Plex should talk with the DEV and get this supported as a official PLEX plugin as it’s that good.
My Settings:
PLEX Update IMDB MAC:
Plex Data Folder: /Users/iMacBeast/Library/Application Support/Plex Media Server
Java Path: /Library/Java/JavaVirtualMachines/temurin-11.jdk/Contents/Home/bin/java
