Why are the IMDB ratings within Plex different than actual IMDB ratings? My movies are continually scored higher in Plex than they actually are. Sometimes just a slight inflation, others quite huge.
Movie A) Plex IMDB 7.6 Real IMDB 7.2
Movie B) Plex IMDB 9.0 Real IMDB 7.5
My server is set to retrieve Rotten Tomatoes ratings, but it rarely shows them.
This is because that was the rating at the time you added it. How old are the movies you are looking at and when did you add it cause ratings will change as time goes on(and people vote).
Edit:
Obviously this CAN be fixed. But only by Plex updating their meta.plex.tv server, as this is where the ratings come from. No need for endlessly debugging your setup guys!
RottenTomatoes ratings share the same issue, in case anyone are considering changing to that, to solve the issue. So, not a workaround.
Plugin / agent support is no longer. In case anyone considered something like the excellent OMDB plugin as a workaround:
