Server Version#:1.43.2.10.687
Tuner Make/Model: HD Homerun Quatro
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Somehow I missed the response to the issue below. I am continuing to have the same problem of all four of my Roku units. (2 4K streaming sticks, 2 4K express units). To recap after a few moments of play the video will rewind and play again from the starting point for a minute or two and the revert to the live TV. In addition frequently, but not always an error message about signal strength or TV antenna will pop up. I dismiss and reselect and everything works fine from then on. BTW i have a 1 gig internet connection and plenty of signal strength a all locations. In addition I never have issues streaming from any of my Plex libraries.
Today 5/24/2026 I again had a rewind issue so am attaching logs generated today. Hope they are helpful. Next time I experience the error noted above I will follow up on this post.
Server Version#: Latest
Player Version#: Latest. I have 4 Rokus and this happens on all of them
When starting to watch live tv via my HD home run tuner on Roku after a few moments the video will replay the last few seconds and then pop up an error message that says in essence “weak signal or antenna problem, click ok”. After clicking OK I reselect the original channel and from there on I have no further issues on any channel.
I have 4 Roku units and this happens on all of them. When I use the HD home run app on the Roku never have this problem. Reason I do not use the HD app is no sound on my older TV’s. One TV is smart one with the older Plex app. The above issue does not happen when using it having bypassed the Roku. All the above leads me to believe the issue is the new Plex Roku app related. BTW all of my libraries stream without any problems.
