Only EAC3: EAE timeout! EAE not running, or wrong folder? Could not read
Until I understand, i’m not installing anything.
I have a proxmox box here somewhere. I will find it and spin it up
From there, I’ll spin up a docker container in that VM.
If that works as expected then we know where to start looking.
Thx for your help. I don’t have choice anyway. If you need help for anything. Ping me.
I found the box
:rofl:
Now to find some :beer: and get to work :wink:
@FunPower_Owner
I found my machine, and :beer:, and am working just fine :slight_smile:
Please observe:
  1. Proxmox 8.2.2
  2. Linux Container (LXC) with PMS in it
  3. No VM
  4. No 3rd Party Docker shenanigans
Am I correct, you started with PMS on Proxmox before all this existed ?
If so, would you consider:
  1. Step up to a proper LXC
  2. like a VM
  3. but with the speed of a Docker container
  4. minus the docker and other sotftware (docker image server / cloudflare parts?
PS: This is my little N100 Beelink test box.
my setup is on VM. Not Contsiner.
ubuntu 20.04
if you dont install Dockserver. Not same.
Did you share the wrong logfile? :thinking:
Oct 11, 2024 17:49:48.331 [140538038479672] INFO - Plex Media Server v1.41.1.9057-af5eaea7a - Docker Docker Container (LinuxServer.io) x86_64 - build: linux-x86_64 debian - GMT -04:00
Oct 11, 2024 17:49:48.331 [140538038479672] INFO - Linux version: 5.4.0-196-generic, language: en-US
Oct 11, 2024 17:49:48.331 [140538038479672] INFO - Processor: 30-core Common KVM processor
Oct 11, 2024 17:49:48.331 [140538038479672] INFO - Compiler is - Clang 11.0.1 (https://plex.tv 9b997da8e5b47bdb4a9425b3a3b290be393b4b1f)
Oct 11, 2024 17:49:48.331 [140538038479672] INFO - /usr/lib/plexmediaserver/Plex Media Server
Oct 11, 2024 17:49:48.331 [140538041014928] DEBUG - BPQ: [Idle] -> [Starting]
Virtual Machine 100 (Dockserver) on node
I use Create VM. not Create CT
Look at the first line of your logfile
It appears, inside your VM, you’re running PMS in a Docker container.
I’m just trying to understand so we can fix this.
I use VM beacau Dockserver not work good on CT.
I try a free install with Ubuntu 22.04
EAC3 work on ubuntu 22.04 on simple install. I will try with the full install.
I finish my fresh install with 22.04. Work Great for now.
Here logs
Start Plex
Wait 2-3min
Start 2 movie with EAC3
If you have any question.
Plex Media Server Logs_2024-10-12_01-40-29.zip (914.6 KB)
Hey im back. Thx for your help but badly is back. Only on browser.
I try on Chrome, Edge, Iphone Chrome. Not work
I try on Pc app Plex, Iphone app. Work.
I’m sure is a Plex.tv probleme. Do you want look on that?
Thx
@FunPower_Owner
Here is an official Dolby test file which plays perfectly for me in Chrome
Please test it on your machine.
You can take a look at this link, I suspect you are facing the same issue.
But unfortunately, there is no official solution for this at the moment.
Same problem on Win and MacOs. Is not a player problem in think.
@FunPower_Owner
How did my testfile play?
If it didn’t play then there’s a problem with your installation.
We need to get DEBUG logs of just that and start figuring it out.
@ChuckPa
Start Plex 02:47
Start Play with Chrome Player on Windows 11, Trancoding: 02:51 Not Working
Start Play with Plex App on Windows 11: 02:55, Trancoding: Not Working
Start Play with Plex App on Iphone: 02:56, Trancoding: Not Working
Befor EAC3 work on iphone but i think only in Direct Play.
Start Play with Chrome Player on Windows 11, Direct Play: 02:58 Not Working, Can’t Play audio Direct Play
Start Play with Plex App on Windows 11: 02:55, Direct Play: Working
Start Play with Plex App on Iphone: 03:01:, Direct Play: Working
I do a mistake on my last post. EAC3 not work on Trancode but work on Direct Play.
Plex Media Server Logs_2024-10-15_03-02-20.zip (6.3 MB)
The only thing I can think of which impacts this is running out of Notify slots or the container’s /config directory path is not on a local HDD/SSD.
Confirm please ?
  1. /config/Library/Application Support/Plex Media Server/ is local to the host and not on a network shared folder / mount / unionfs mount ? The transcoder temp must be on a real HDD/SSD
  2. You don’t have such a high number of folders being monitored that you’re filling the default notify table? (8192 on older kernels, 65536 on newer kernels)
i don’t have the /config/…
Is on: /opt/appdata/plex/database/Library/Application Support/Plex Media Server
But yes. Is in my Real SSD in my Machine. But all my video is on my NAS via Internet.
I don’t know how check Notify.
Kernel version: 5.15.0-122-generic
