Only one question before diving deep into Plex
Hello,
I am not familiar with Plex and only experimented a few times with it.
It is a great piece of software but i can’t figure out just one thing (a deal breaker for me) :
Is it realy not possible to add movies (easily) manually? I have a lot of movies who aren’t presented correctly. That is no problem as long as i can add/correct my own data like covers, years, physical filelocation etc. I know it is somehow possible but very very lengthy and not for all movie-data.
The Plex GUI is (almost) perfect, user-friendliness is top, the suported formats are okay but i don’t find any option to add manually (in a normal way such as Synology DSVideo for example) a movie with my own data.
Like i said, i am not familiar with Plex so i gues i’m searching in wrong places?
Best regards,
Léon
https://support.plex.tv/articles/200264746-quick-start-step-by-step-guides/
https://support.plex.tv/articles/categories/your-media/
https://support.plex.tv/articles/201543057-why-is-some-of-my-content-not-found/
The above will help you to tip off Plex to fetch the correct metadata for your movies.
If you don’t actually mean “movies” (i.e. stuff that you might see in a movie theater), but rather videos of your family, or instruction videos etc, then you want a library of the type “Other Videos”.
Thanks for the quick response :pray:, i already saw that option but i’m afraid that i must use about 50% of my media to set as “Other Videos” because of the formats (for example ISO) that are not recognized. (Normal DVD (Laurel and Hardy) and/or BR-rips also not recognized, some do and some don’t) And i use for example a folder “Music Video’s” and when a Music Video is not recognized i must add this in “Other Videos” so that is not the way to go i think. I will try if i can move the Music Video data afterwards to the correct folder. :pray: Further is see there are naming recommendations i was not aware of, i thought (wrong) that Plex would search within the file itself. So for example 123.mkv is not recognized as een Queen music Video, i must name the file Queen.mkv?
Even an Other Videos library won’t help with those. ISO containers and DVD/Bluray folder structures are not supported in Plex. https://support.plex.tv/articles/201426506-why-are-iso-video-ts-and-other-disk-image-formats-not-supported/
There is no library type for Music Videos. These can only go into an Other Videos library.
Or with higher effort into a series library which has been set to “personal media”.
I use indeed personal media for the music video’s, sorry. The support (not) of ISO i was aware of. That’s a shame because a lot of programms who are not as good looking as Plex are much easier to add user data and support a lot more formats. Thanks again for the quick respons.
