I kinda love the app, its UI and everything about it, except everything I play is OOS. Anyone else get this?
Yep, even though the media is being transcoded (and it shouldn't be), how can it be Out Of Sync?
Regards
Well I guess transcoded files are the most prone to be out of sync, but I dont have this problem with other clients that require transcoding (iphone/ipad).
Hope this is fixed soon. Pretty much useless as it is now.
@RockStar Can you share 5 minute sample of the the media file with OOS issue.
Sorry for the late reply. I get sync problems with ALL media. I can set up a temp account for you on my server and you can take a pick if you want.
I am also getting this issue. It seems to be OOS by about .5 seconds.
