Open PHT and Harmony Remote
Can somebody please tell me how to use harmony remote with open pht.
Set it up as a Microsoft media center remote.
No need to change anything after that. Play around with the colored buttons too :slight_smile:
I ended up using a Flirc. Works fine.
How do I start pht as part of an activity?
I mean is there a button short cut to start pht?
In Windows, what I do is pin the OpenPHT app to the taskbar, and then you can use the WIN button + the order number to start it via the Harmony remote.
So here I’ve pinned it as the first real app on the task bar (We ignore the first 3 system icons on the taskbar):
Then in the Harmony app I map the following button combination:
isn’t there an easier way. now it is open source, can we map it to behave live windows media centre, so that it starts with green button equivalent on harmony.
If you’re on Mac you can create a service to start app with Automator, then create a keyboard shortcut. Works great with a Flirc.
