hello here is my fresh build of OpenPHT by Kwiboo
based on LibreELEC 8.2 by kszaq
Devices:
Odroid C2
RPi
RPi2
S805
S905
S912
WeTek Core
WeTek Hub
WeTek Play
WeTek Play 2
soon:
Generic x86-64
imx6
Intel_EGL
H3 but with SW decode only
Devices:
Odroid C2
RPi
RPi2
S805
S905
S912
WeTek Core
WeTek Hub
WeTek Play
WeTek Play 2
soon:
Generic x86-64
imx6
Intel_EGL
Thanks alot! For Odroid C2 should i use the s905 image or wait?
wait today i will release it
​Odroid C2 build is on github
Thats just great!
Hey, nice work. Did you plan a build for rpi2 too?
can confirm its working great for the C2!
@kras12 said:
Hey, nice work. Did you plan a build for rp2 too?
Yes i will upload it yesterday
@veisen said:
@kras12 said:
Hey, nice work. Did you plan a build for rp2 too?Yes i will upload it yesterday
Compile is long time process 5-7h per device
wetek hub would be nice too, great work, thanks alot
This build solved alot of my problems with the old 1.8 version… many thanks!
Do you have a change log for 1.9? Any chance it’ll release for generic x86?
Wetek hub is on the way and i will try generic x86
RPi and RPi2 is on git hub
untested if this build not working upload log please
i havent got this device
4k patch is on the git s912 can someone try it please
systemd error on s905 and 4k is fixed
https://github.com/Veisen/OpenPHT/releases/download/1.1/OpenPHT-Embedded-S905.arm-8.2-devel-20180408052801-r26548-g3a13cd9.tar
RPi, and RPi2/3 are working
Thank you.
Can someone please try to briefly summarize what the advantage of this built is against what we had before.
Or answer the biggest burning question: is the audio sync/lag bug fixed?
Just loaded up the image on my ODroid C2. Seems to work fine. Will look to see if the audio sync/lag issue is fixed and will report back.
Thanks for this new build! Glad to see the best Plex embedded player isn’t dead! I was starting to lose all hope.
Is a changelog available for the 1.9 release?
I heard on the LibreELEC forum that DTS passthrough does not work ? is it true ?
And to be clear if i install this on a s905x s905d or s912 or wetek play 2 device it will play back HDR and passthrough True HD Atmos ?
Thanks for your excellent work @veisen
