OpenPHT and WMC
Ok i just learned about OpenPHT and that PHT is no longer being updated.
I have been running PHT in WMC for a few years and have a few question about changing to OpenPHT.
  1. I assume i have to uninstall PHT before installing OpenPHT, it will not upgrade PHT?
  2. Will OpenPHT add a link to the WMC menu like PHT did?
  3. I had my remote setup to control WMC and got PHT to work with the same remote. Will OpenPHT still work that way or will i need to reprogram my remote different from WMC commands.
I may have to try this stuff in a VM just to test it out.
  1. both can coexist
  2. yes
  3. should work the same. if you customized one, you may need to customize the other. as far as I know, the code is the same, except OPHT has had some fixed applied.
Expounding a bit on @jwaltrip4 's answer:
    @jwaltrip4 said:
  1. both can coexist
    They have different install directories since the name changed. So you can have both installed without conflict.
@Rainey01 said:
3) I had my remote setup to control WMC and got PHT to work with the same remote. Will OpenPHT still work that way or will i need to reprogram my remote different from WMC commands.
@jwaltrip4 said:
  1. should work the same. if you customized one, you may need to customize the other. as far as I know, the code is the same, except OPHT has had some fixed applied.
    The PHT code was merged with the Rasplex project, which was a specialized fork of the PHT originally anyway. This part of the code was not changed. If you used a remote.xml or keyboard.xml to customize your remote, you’ll need to copy those custom files to the appropriate directories in the OpenPHT installation directory.
Thanks guys. I now must try getting Plex working again.
I had upgraded to the new plex server 1.1.4 but than downgraded to the older version i was running 9.16.6.
Ever since then Plex server crashes when when i press the stop button, while playing a stream in a channel all most every time.
I think the newer version added somethings or changed a few file settings and no mater what i do plex server crashes and leaves all the scripts running. No crash file is made, nor server error other then,
Oct 04, 2016 23:23:02:971 [5728] VERBOSE - Statistics: (P7Win8MC) Reporting 257 bytes for account 1 on LAN: 1 2244 Oct 04, 2016 23:23:03:475 [5720] VERBOSE - * containerKey => /playQueues/ 2245 Oct 04, 2016 23:23:03:475 [5720] VERBOSE - * duration => 4260000 2246 Oct 04, 2016 23:23:03:475 [5720] VERBOSE - * key => /system/services/url/lookup?url=http%3A%2F%2Fjav789.com%2Fmovie%2Fyuu-759.html 2247 Oct 04, 2016 23:23:03:476 [5720] VERBOSE - * playQueueItemID => 0 2248 Oct 04, 2016 23:23:03:476 [5720] ERROR - Had trouble breaking playQueueVersion 2249 Oct 04, 2016 23:23:03:476 [5720] ERROR - ERROR: Parsing request failed.
I see some folder under the Ples Media Server directory i don’t remember like Codecs and crash reports, both were made on 9-14 that is when i installed a plex upgrade.
I need to reinstall clean, but try and keep my settings and watched databases, So i am look for that kind of info, so far all i seem to find is just general clean install info and not custom.
