Im wondering if its just not compatible with my os cause it crashes to desktop almost immediately after being run, running from terminal just returns segmentation fault. i have no logs since idk where the config for openpht is. any info would be great
I’m not using mint but I use cinnamon desktop as well.
Same error on latest debian jessie with this build https://github.com/RasPlex/OpenPHT/releases/download/v1.6.2.123-e23a7eef/openpht_1.6.2.123-e23a7eef-jessie_amd64.deb
Any suggestions?
It’s not possible to help without a log, you can find it here :
~/.plexht/temp/plexhometheater.log
The plexhometheater “segfault” line from the command “dmesg” (or logfiles) would also be helpful, e.g. after a crash enter:
dmesg | grep -i plex
Thank you very much bkury.
Now that I found the log I was able to fix the issue myself.
I turns out that libcurl was missing - so I installed libcurl4-openssl-dev and it’s working fine
