OpenPHT for Wetek Hub?
Will OpenPHT support the Wetek Hub?
Shhhhh! But I heard it maybe in the works. :slight_smile:
Where did you hear that? I only heard it might come to SHIELD TV.
Hopefully be in next release.
@samplex: the prerelease is already very promising.
Gerald
Ordering one now. :slight_smile:
If it was possible to dual boot Android on eMMC and OpenPHT on SDCard, this would be quite the little media box.
@gdachs or @NedtheNerd ,
Do either of you know if the included remote works with the pre-release? I’ve read some issues with the remote not supported on Kodi when used on some early release models.
The power button of the remote doesn’t power off the box, this is a known issue, beside that it works.
Gerald
SHIELD too? :wink:
