OpenPHT has exited when left unused for a while
This happens a few times per week. After leaving OpenPHT unused for several hours or more with the TV turned off, when i return OpenPHT is not running and no error on screen just the Windows 8.1 desktop. I can launch OpenPHT again no problems, until happens again a few days later. Hard to tell exactly when it exited hope the logs show something.
Using v1.6.1 Logs attached.
From the log it looks like there is some problems loading some poster/fanart, possibly not the source of the crash but should not hurt to clear out corrupt cached data.
Suggest you:
  1. Stop OpenPHT
  2. Remove the Database and Thumbnails folders from C:\Users\paul\AppData\Roaming\OpenPHT\userdata\
  3. Start OpenPHT
Note: All necessary data in Database and Thumbnails will be regenerated and cached when you restart OpenPHT
Thanks Kwiboo. Done that now, will wait and see this week.
I’m still seeing this problem - the above did not resolve it. Any other clues from the log I attached in the original post ?
New log attached. Last log entry 00:49 which must be when OpenPHT app crashed. Any advice?
EDIT : I was looking at photos and home videos earlier in the evening and kicked of a full home video library refresh before going to bed - so lots of log entries for that activity. Don’t think the refresh is causing this OpenPHT crash/exit and it’s done it many time before even without a refresh happening.
Anyone any thoughts on this ? Wonder if it could be related to the scheduled maintenance tasks that PHS does by default 2am-5am ? Wouldn’t have thought that could kick out the client though. I’ve changed the scheduled maintenance to be from 2am to 3am to see what happens - the problem hasn’t reoccurred for 3-4 days now … wait and see. I’ve set up window perfmon logging also - can see small spikes in CPU & disk usage during maintenance other than that nothing else of concern.
