OpenVix HRTunerProxy Plex Live TV with FreeSat
Hello,
Really sorry if this has been covered before but I’m trying to get my Plex server to connect with a DVR under the Live TV section. The DVR is an Enigma2 box running OpenVIX with the HRTunerProxy plugin, I’m initially able to get Plex to see the device but only by manually entering the IP address with the port number, but when I go to scan channels it says ‘Could not communicate with the device’. I’ve been trying to search for the answer in forums but I’m completely lost. Could someone please help? thank you
Just wanted to update this incase anyone else has the same issue. I resolved this, turns out that when entering postcode for finally part of Plex setup the full post code of your location will not work and cause Plex to freeze, you have to enter the first part of your post code only! All good now.
