Hello. From today I can connect to Plex
http://plex.tv/web/tv/opera
Why?
Tnx
Why?
Tnx
That is a really old version of the app and afaik it does not support TLS 1.2.
Old and what? I must to disable SSL on my Plex server?
The app will not load, regardless of your server. It cannot connect for authentication, etc. If you click the sign in button nothing will happen, attempting to change preferences will probably not save for example.
Plex suspended the proxy server content from today ? Yesterday I could watch movies.
I’m not aware of any changes done today/yesterday. We disabled old security protocols a couple weeks ago at the end of September. If you left your TV on Plex then I suppose things might have already been saved in your TV’s memory. But just turning off your TV likely would have wiped them. But the app cannot load from our servers properly because it does not support current security.
To be clear loading that app through that link was never supported. Was something users figured out how to do after Sony removed the Vewd store if I recall.
