Optimized Versions Broken?
The conversions may or may not occur, but regardless, I can no longer view the Optimized Versions settings/change it’s config/delete it, etc
Server Version#: 1.41.0.8930, Linux (Ubuntu)
I have the same issue. I can setup new optimisations, and they will show in the queue, but does now show up in the “Optmized versions” page.
Plex Version 1.41.0.8930
I run Plex on Unraid version 6.12.6
Intel® Xeon CPU E5-1650 v2
16 GB RAM
GPU: Quadro K2000
I have the same issue as jjISD and halvliter1.
“Optmized versions” page broken
Plex Version 1.41.0.8930, Windows 11
I just noticed that this thread was created under the “Plex Pass Betas”, is this the correct place for this issue ? Should it have been raised under a different section of the forum ?
I’m assuming it should? I’m a Plex Pass subscriber using the PMS Beta, issue wasn’t present on the non Beta Release
It can be moved if necessary. Whatever gets it visibility
Reported it awhile back, just hasn’t been fixed yet. I was hoping it would be in this last one but not yet. 1.40.5.8897 is the last functioning version for optimized lists.
