Please add an option to disable swipe to remove from playlist on Plexamp.
On my phone you swipe from the side to go back. Constantly I am accidentally removing a song from a playlist when I’m trying to go back and then I have no idea which song I just deleted.
If I’m in a hurry and I don’t have time to be super careful then I just won’t listen to my playlists because the risk of removing something from my playlist is just too high.
If I want to remove a song from a playlist I can click the three dots then select remove from playlist in the context menu. I will never ever ever use swipe to remove
The only work arounds are listening to something other than my playlist or using a different music app all together.
In my opinion this one of the biggest flaws with the Plexamp.
Edit: after creating this post, i see that remove from playlist is no longer an option in the context menu…
