Option to only create EDL commercial files without cutting?
Is there an option to only scan DVR recordings for commercials, and skip the cutting part?
MCEBuddy! :slight_smile:
Sorry. Should have mentioned that I’m running Plex on Ubuntu…
I believe you can run comskip/comchap to do the same thing on Linux.
Yep. Just curious if it was possible to do it with OOTB functionality.
