So it is simple, while Commercial cutting is pretty awesome as a feature, I am sure with the many channels out there, there is a lot to think about for how to tweak the configuration perfectly, and I had seen no options for this inside plex itself. So while we are perfecting this particular feature I think it would be awesome if we could have a check box to retain the original file somewhere on the server, so if something important gets cut out we can still have the original file in tact, and do the removal ourselves. Just a thought…
http://127.0.0.1:32400/:/prefs/set?dvrRemoveComskipFiles=0&X-Plex-Token=YOURTOKEN
replace 127.0.0.1 with the IP address of your Plex server, in case it runs on a different machine
replace YOURTOKEN with your own X-Plex token https://support.plex.tv/hc/en-us/articles/204059436-Finding-an-authentication-token-X-Plex-Token
This is a developer option. Don’t expect Plex to keep tab on the various cut and uncut versions. You need to manage those yourself.
Must be close…
cannot set preference value for unknown preference dvrRemoveComskipFiles
I want to throw in there, its plex server on fedora 64-bit if that makes a difference, I am not sure why it didn’t work for me.
Havok…
Once implemented, can you tell me if it simply puts both files in the same location? I don’t care, it is more of a just in case, I don’t want to miss anything that is important.
Havok
Try to add it to your Preferences.xml file manually
https://support.plex.tv/hc/en-us/articles/201105343-Advanced-Hidden-Server-Settings
I will indeed let you know when I can try, gotta head out at the moment.
Early 2021 clean-up: implemented (as per Otto’s explanation)
