Optional Agents for TV metedata
Hi, I'm desperate to be able to use other agents for my TV collection as TheTVDB is really bad sometimes. I thought this was possible in older versions, but I don't seem to be able to find it now (PMS 9.8.17). Is there anyway to use TVRage for an agent? For some of my collection, they have much more accurate and better information that TVDB.
Thank
This seems to be the best option right now:
https://forums.plex.tv/topic/73947-alpha-wrestling-metadata-agent/
Thank
Just ran across this -it's an old post so you may of figured out your way around the metadata agents by now.
In case you didn't find what you needed- you should have The movie database and fanart.tv added to the main TVDB agent. Also add The main TV agent "the movie database" this includes the TVDB, TVrage and of course TMDB within that main agent.
With both of those, you shouldn't have any issues with metadata and artwork for just about any TV show. Ive yet to run across an issue with any TV show lacking in metadata. Unless you're talking about something pretty rare or sports- both agents should have you well covered.
Hope this helps.
