I have a bunch of recordings of concerts from DVDs and BluRays, which while they are appearing currently under Movies, (and a few under TV Shows)… I would like to separate these out to a separate section/library.
Would I be able to create a new section or library to put these programs in (and move the content into this)?
If so, how can I do this?
I see when I go to Add Library it asks for a type: Movies, TV Shows, Music, Photos, or Other Videos.
I have quite a few downloaded concerts as well. I use windows 11 and a dedicated drive for Plex. For the Concert Video section I choose Other Video and then I select local for the meta information. I like to set up the files by the band name and then date of the show. That way all of the bands shows are in a separate directory and the shows are by date.
I do the same with music but I let Plex find the meta data for the music albums.
For music files the format would be:
D:Music\Band name\albums
for example:
D:\Music\AC-DC\Back In Black
D:\Music\AC-DC\Let There Be Rock
D:Music\Aerosmith\Toys In The Attic
For concert Videos:
D:\Concert Videos\Band\Date and Show and Location (any special info)
For example:
D:\Concert Video\Grateful Dead\1976-08-04 Roosevelt Stadium NJ (full show)
D:\Concert Video\Rolling Stones\1969-07-05 Hyde Park London
Extra:
For each show I do a Google AI search for: “Date, Band, Highlights and Setlist”
I add the results to the description of the show.
For example:
1976-08-04 Grateful Dead Highlights and Setlist
I also try to find a show poster or announcement to add to the Poster image.
It may not be the best way but it works for me. I hope that helps.
(edited to at the proper directories for Music and Concert Video)
Since concerts are generally considered single-event programs they appear as Movies in metadata providers quite often. As long as you have them all in a directory outside your normal movies you can just make a new Library of type Movies and name it “Concerts and Music” or similar.
Personally I still keep them in the same directory as my movies and just have them all in a collection (with only the collection visible in the library, not the individual titles), but if you want this to be a permanent fixture on the home page a separate library would be better.
I’m using a “Movies” library for this kind of content. Because it allows you to add local extras. Concerts often come with bonus content, which l usually like to have.
If there is an item for which there is no metadata on TheMovieDB, don’t forget to explicitly Unmatch it before adding your own metadata manually.
