Which tipe of library for concert live music?
I have a little problem, on my live music library (I choose live music) my concert are 2 or 3 or more cd or parts… try to name as suggested but they are not grouped correctly…
and also I prefer posters vertical image… but I see only horizontal one…
any suggestions?
Personally I use “Movies”.
There are actually a lot of concert DVDs and BluRays listed on TheMovieDB, so that you have a good chance of getting metadata automatically.
If you encounter a title that is not listed, either add it yourself to TheMovieDB
or type in the metadata manually into Plex.
Just make sure to explicitly “unmatch” the movie in Plex before you do that.
Using this library type also makes it easy to add some of the bonus content, just like other local extras.
As for the multiple disc issue:
You can use the -disc1, -disc2 etc. suffix.
However, this may not work well with some client types.
If you have ripped the files yourself, my recommendation is to merge the parts immediately after ripping, and apply compression afterwards. [HowTo]: joining multi-part movies files with MKVtoolnix GUI
