2 things I’d like to do with my playlist.
- Sort items alphabetically
- be able to mark all as viewed or not viewed, like my TV shows
Is this possible?
Is this possible?
Any ideas here???
No to 1).
Regarding 2) you might be able to rig something by using the custom filters and the “Track played” filter.
Maybe explain your use case a little bit more in detail.
My “other” videos are basically homemade videos of different family members. Several movies were seen only the first half (2 minutes, etc.). When sharing, the pop up window asks something like ……“start video at the 2:00 mark…or…play from beginning”. Over on the TV shows section, you can select the "…
" and then the pop up can ask “Mark all as viewed”, and then vice versa, you can mark them all as unviewed. Which would mean I could start fresh on each video.
PS- it’s too bad you can’t alphabeticallize, because I add to the playlists at varying times. If I want to see Aunt Edith (for example), she’d be right up at the top of the list, or I can scroll down if I wanted to see Uncle Wilbur.
Gotcha. No, the ability to edit items in a playlist is unfortunately non-existing.
Setting the playback status and other changes are only possible either on the pre-play screens or in the regular library view.
