Original Playback isn't an option
I have one MKV file that does not give me an option to play the original stream, but I have all options for a converted version of the movie. Any ideas why Play Original Quality is not an option for this file?
Server Version#: 1.21.4.4079
Bitrate 15523 kbps
Width 3840
Height 2160
Aspect Ratio 1.78
Video Resolution 4K
Container MKV
Video Frame Rate 24p
Video Profile main 10
Codec HEVC
Bitrate 14883 kbps
Bit Depth 10
Chroma Subsampling 4:2:0
Coded Height 2160
Coded Width 3840
Color Primaries bt2020
Color Range tv
Color Space bt2020nc
Color Trc smpte2084
Frame Rate 23.976 fps
Height 2160
I’m having the same problem on the NVIDIA Shield. I was able to get Original Quality back by disabling Audio Passthrough on HDMI but I’m still getting a tone mapped SDR version that stutters on playback.
@deni
Are you having this issue with all movies?
No, only 4K HDR/DV content. I’ve made some headway and have the option back but plex is still transcoding.
