In the article Multiple Editions | Plex Support it says in the details page of a movie with multiple editions there is that section. I am missing it even after a plex dance. Having two versions of Saw3. See both versions in lib. Both got the correct tag “Unrated” and “Directors’s Cut”. But there is no “other editions” section in movie details page. Am I missing sth?
How did you organize / name those files?
Sounds like Plex might have matched them as different movies?
Otherwise… the “Other Editions of…” should currently be showing below the extras of a movie.
I guess there’s no other hubs showing below the collection hub?
What version of Plex Web are you using? I’m not sure the features are already available in their entirety using the bundled version of Plex Web on the latest version of PMS.
Ah there is no info about minimum required web player version, so I did not check that. Under app.plex.tv it works. Thank you!
I’m on the latest PMS (beta version 1.28.2.6106) and my bundled web version is 4.87.2 which I would say is the minimum bundled web app you need to be able to see this, as it’s working for me.
If you aren’t on the beta update channel, that would explain why you don’t have it locally yet.
-Shark2k
