Overlapping channel #s?
I am trying to integrate multiple liveTV sources. Unfortunately, some of the channel #s overlap. How do I get both in the Guide?
Is this the problem you are having? You are trying to use multiple sources with guides from different countries or perhaps different regions, whose numbering in the listing does not match ? I couldn’t find an answer, nor could anyone confirm that they have successfully solved the issue.
