Parental control
I there any way to hide certain films ( eg. Thriller, horror) from children in the home?
Disable a library or something like that :slight_smile:
Someone with more expertise can correct me, but I think you need to use the new user controls in the lastest version of PMS.  From memory I think you need a PlexPass for this but I may be wrong.
User controls are on the to-do list to be implemented in PlexConnect but not available at the moment.
Personally, I have several libraries and tell the kids not to go into some of them.  Works with my kids but they're only 10 and still scared of me :).
Yeah multi user support will come with MyPlex integration.
Multi user is still pretty new but you can share specific sections.
You will need a PlexPass for this specific feature.
Will that work also then for ATV ?
