Partial Scan Enabled, adding multiple episodes make scanner run through entire library?
Server Version#:
Player Version#: N/A
Scanner Version#: 1.20.4.3517
Advanced Settings: Scan Automatically, Run Partial Scan
  1. Like the title said I add a show with multiple episodes at once
  2. First episode (or sometimes the first batch to hit the folder if there is a delay moving) scans in no problem then it starts going through other shows. (See log below at bolded area)
  3. It will say “Scanning TV Shows” in the activity section on the top of the screen
  4. It’s going through each top level folder, seeing no changes are made then moving to the next
  5. If you go to TV section and cancel scan it will cancel this scan and then it moves onto the next episodes and scans them all in properly and quickly like it’s supposed to and finishes
I don’t know when this started as I don’t normally drop multiple episodes of a show in and if I do I just go away and come back hours later
In the end everything gets scanned in properly, sometimes I have to manually match a show. No issues except for the first episode/batch being added then it going through all the other folders.
There are no unmatched shows, I have heard in the past it will try to match unmatched during a scan don’t know if that’s still true.
Partial Log: It just keeps cycling through shows either removing items from the “Map” or not. It might not go through all the folders, I stop it before it has a chance but it ran for 30 minutes this time.
Nov 08, 2020 20:28:53.205 [0x146d97010700] INFO - Plex Media Scanner v1.20.4.3517-ab5e1197c - Docker Docker Container (LinuxServer.io) x86_64 - build: linux-x86_64 - GMT -05:00
Nov 08, 2020 20:28:53.206 [0x146d97010700] INFO - Linux version: 5.8.13-Unraid, language: en-US
Nov 08, 2020 20:28:53.206 [0x146d97010700] INFO - Processor Intel(R) Xeon(R) CPU E5-2680 0 @ 2.70GHz
Nov 08, 2020 20:28:53.206 [0x146d97010700] INFO - /usr/lib/plexmediaserver/Plex Media Scanner --scan --refresh --section 6 --activity 6f4d3a5a-23a5-41d5-b6cd-3855b7d6a97f --directory /data/Media/Television
Nov 08, 2020 20:28:53.253 [0x146d9e9c3bc0] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.26.0, threadsafe=1
Nov 08, 2020 20:28:53.722 [0x146d9e9c3bc0] DEBUG - It took 100.000000 ms to retrieve 4311 items.
Nov 08, 2020 20:28:57.067 [0x146d9e9c3bc0] DEBUG - It took 70.000000 ms to retrieve 4311 items.
Nov 08, 2020 20:29:00.200 [0x146d9e9c3bc0] DEBUG - It took 60.000000 ms to retrieve 4311 items.
Nov 08, 2020 20:29:03.315 [0x146d9e9c3bc0] DEBUG - It took 60.000000 ms to retrieve 4311 items.
Nov 08, 2020 20:29:06.388 [0x146d9e9c3bc0] DEBUG - It took 60.000000 ms to retrieve 4311 items.
Nov 08, 2020 20:29:09.617 [0x146d9e9c3bc0] DEBUG - It took 70.000000 ms to retrieve 4311 items.
Nov 08, 2020 20:29:12.858 [0x146d9e9c3bc0] DEBUG - It took 60.000000 ms to retrieve 4311 items.
Nov 08, 2020 20:29:23.598 [0x146d9e9c3bc0] DEBUG - HTTP requesting PUT http://127.0.0.1:32400/activities/?percentComplete=0
Nov 08, 2020 20:29:23.598 [0x146d8e89a700] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/cullTimeline?librarySectionID=6&sinceTime=1604884163
Nov 08, 2020 20:29:23.601 [0x146d9e9c3bc0] DEBUG - HTTP 200 response from PUT http://127.0.0.1:32400/activities/?percentComplete=0
Nov 08, 2020 20:29:23.601 [0x146d9e9c3bc0] DEBUG - Scanning TV Shows using en(Plex Series Scanner) with 82013 current media items and 1 section locations in the database.
Nov 08, 2020 20:29:23.602 [0x146d8e89a700] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/notify/cullTimeline?librarySectionID=6&sinceTime=1604884163
Nov 08, 2020 20:29:23.953 [0x146d9e9c3bc0] DEBUG - Performing a scan with ‘Plex Series Scanner’ (language: en virtual: 0).
Nov 08, 2020 20:29:23.953 [0x146d9e9c3bc0] DEBUG - * Scanning /data/Media/Television
Nov 08, 2020 20:29:24.161 [0x146d9e9c3bc0] DEBUG - Scanner: Processing directory /data/Media/Television (parent: no)
Nov 08, 2020 20:29:26.785 [0x146d9e9c3bc0] DEBUG - Skipping over directory ‘’, as nothing has changed; removing 0 media items from map.
Nov 08, 2020 20:29:29.357 [0x146d9e9c3bc0] DEBUG - Scanner: Processing directory /data/Media/Television/Blood & Water (parent: yes)
Nov 08, 2020 20:29:29.601 [0x146d9e9c3bc0] DEBUG - Scanner: Processing directory /data/Media/Television/Blood & Water/Season 01 (parent: yes)
Nov 08, 2020 20:29:29.907 [0x146d9e9c3bc0] DEBUG - Directory had 1 files, database had 0 files, can’t skip.
Nov 08, 2020 20:29:30.035 [0x146d9e9c3bc0] DEBUG - Looking for path match for [/data/Media/Television/Blood & Water/Season 01/Blood & Water - s1e01 - Fiksation [WEBDL-1080p] [x264 EAC3] [ 5.1 Audio] [8bit].mkv]
Nov 08, 2020 20:29:30.042 [0x146d9e9c3bc0] DEBUG - Skipping hash check, no size match for 1160830976 bytes.
Nov 08, 2020 20:29:30.042 [0x146d9e9c3bc0] DEBUG - No match for hash.
Nov 08, 2020 20:29:30.048 [0x146d9e9c3bc0] DEBUG - Checking descendants of Blood & Water
Nov 08, 2020 20:29:30.049 [0x146d9e9c3bc0] DEBUG - → Searching down into Blood & Water/Season 01
Nov 08, 2020 20:29:30.049 [0x146d9e9c3bc0] DEBUG - Checking descendants of Blood & Water/Season 01
Nov 08, 2020 20:29:30.052 [0x146d9e9c3bc0] DEBUG - Creating show ‘Blood & Water’
Nov 08, 2020 20:29:30.052 [0x146d9e9c3bc0] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.052 [0x146d9e9c3bc0] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.055 [0x146d9e9c3bc0] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.076 [0x146d9e9c3bc0] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.077 [0x146d9e9c3bc0] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.079 [0x146d9e9c3bc0] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.080 [0x146d9e9c3bc0] DEBUG - Added new metadata item (Blood & Water) with ID 1751431
Nov 08, 2020 20:29:30.080 [0x146d9e9c3bc0] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.080 [0x146d8e89a700] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Nov 08, 2020 20:29:30.080 [0x146d9e9c3bc0] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.083 [0x146d9e9c3bc0] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.083 [0x146d9e9c3bc0] DEBUG - Updating metadata item (save) (Blood & Water) with ID 1751431
Nov 08, 2020 20:29:30.086 [0x146d8e89a700] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Nov 08, 2020 20:29:30.087 [0x146d8e89a700] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Nov 08, 2020 20:29:30.087 [0x146d9e9c3bc0] DEBUG - Creating season 1 for show ‘Blood & Water’
Nov 08, 2020 20:29:30.087 [0x146d9e9c3bc0] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.088 [0x146d9e9c3bc0] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.088 [0x146d8e89a700] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Nov 08, 2020 20:29:30.090 [0x146d9e9c3bc0] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.094 [0x146d9e9c3bc0] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.094 [0x146d9e9c3bc0] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.097 [0x146d9e9c3bc0] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.097 [0x146d9e9c3bc0] DEBUG - Added new metadata item () with ID 1751432
Nov 08, 2020 20:29:30.098 [0x146d8e89a700] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Nov 08, 2020 20:29:30.098 [0x146d9e9c3bc0] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.098 [0x146d9e9c3bc0] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.099 [0x146d8e89a700] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Nov 08, 2020 20:29:30.100 [0x146d9e9c3bc0] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.105 [0x146d9e9c3bc0] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.105 [0x146d9e9c3bc0] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.110 [0x146d9e9c3bc0] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/library/changestamp
Nov 08, 2020 20:29:30.111 [0x146d9e9c3bc0] DEBUG - Added new metadata item () with ID 1751433
Nov 08, 2020 20:29:30.112 [0x146d8e89a700] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Nov 08, 2020 20:29:30.113 [0x146d8e89a700] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Nov 08, 2020 20:29:30.130 [0x146d9e9c3bc0] DEBUG - HTTP requesting PUT http://127.0.0.1:32400/activities/?percentComplete=%2B0.037443269&subtitle=Blood%20%26%20Water%20-%20Season%2001
Nov 08, 2020 20:29:30.133 [0x146d9e9c3bc0] DEBUG - HTTP 200 response from PUT http://127.0.0.1:32400/activities/?percentComplete=%2B0.037443269&subtitle=Blood%20%26%20Water%20-%20Season%2001
> Nov 08, 2020 20:29:30.133 [0x146d9e9c3bc0] DEBUG - Scanner: Processing directory /data/Media/Television/Upright (parent: yes)
Nov 08, 2020 20:29:30.242 [0x146d9e9c3bc0] DEBUG - Skipping over directory ‘Upright’, as nothing has changed; removing 0 media items from map.
Nov 08, 2020 20:29:30.243 [0x146d8e89a700] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/updateProgressMessage?message=Scanning%20Upright
Nov 08, 2020 20:29:30.246 [0x146d8e89a700] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/updateProgressMessage?message=Scanning%20Upright
Nov 08, 2020 20:29:30.366 [0x146d9e9c3bc0] DEBUG - Scanner: Processing directory /data/Media/Television/Upright/Season 01 (parent: yes)
Nov 08, 2020 20:29:30.528 [0x146d9e9c3bc0] DEBUG - Skipping over directory ‘Upright/Season 01’, as nothing has changed; removing 8 media items from map.
Nov 08, 2020 20:29:30.528 [0x146d8e89a700] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/updateProgressMessage?message=Scanning%20Upright%2FSeason%2001
Nov 08, 2020 20:29:30.528 [0x146d9e9c3bc0] DEBUG - HTTP requesting PUT http://127.0.0.1:32400/activities/?percentComplete=%2B0.037443269&subtitle=Upright%20-%20Season%2001
Nov 08, 2020 20:29:30.531 [0x146d9e9c3bc0] DEBUG - HTTP 200 response from PUT http://127.0.0.1:32400/activities/?percentComplete=%2B0.037443269&subtitle=Upright%20-%20Season%2001
Nov 08, 2020 20:29:30.531 [0x146d9e9c3bc0] DEBUG - Scanner: Processing directory /data/Media/Television/Undergrads (parent: yes)
Nov 08, 2020 20:29:30.531 [0x146d8e89a700] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/updateProgressMessage?message=Scanning%20Upright%2FSeason%2001
Nov 08, 2020 20:29:30.651 [0x146d9e9c3bc0] DEBUG - Skipping over directory ‘Undergrads’, as nothing has changed; removing 0 media items from map.
Nov 08, 2020 20:29:30.651 [0x146d8e89a700] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/updateProgressMessage?message=Scanning%20Undergrads
Nov 08, 2020 20:29:30.655 [0x146d8e89a700] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/updateProgressMessage?message=Scanning%20Undergrads
Nov 08, 2020 20:29:30.751 [0x146d9e9c3bc0] DEBUG - Scanner: Processing directory /data/Media/Television/Undergrads/Season 01 (parent: yes)
Nov 08, 2020 20:29:30.956 [0x146d9e9c3bc0] DEBUG - Skipping over directory ‘Undergrads/Season 01’, as nothing has changed; removing 13 media items from map.
