I’m unable to get the pause during refresh rate change setting to work on a fresh 1.6.2 embedded install. Any others with this issue? I’ve just recently switched to OpenPHT on my Chromebox. I’ve attached a log here: https://github.com/RasPlex/OpenPHT/issues/128
Other than this, OpenPHT is working great for me!
I does not work for me either on Windows 7
As I stated in the above issue, I experienced the exact same thing and when I “upgraded” to 1.5.2 embedded, set the setting there and confirmed it worked there, a subesquent upgrade to 1.6.2 and the setting continued to work. I have no clue why this would be the case but it could be worth trying to see if it works for you.
I simply dropped the .img file into the Update dir and rebooted to “upgrade” to 1.5.2. I can’t remember if I had to extract the KERNEL and SYSTEM files out or not but I think I did not have to do that.
