Permission problem audio transcode path /tmp/pms-*
Server Version#: 1.19.4.*
Player Version#: webclient
Jun 14, 2020 19:27:30.000 [0x7fb5537fe700] Fehler — [Transcoder] [eac3_eae @ 0x2a8ca80] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-9717be1a-5061-48f9-8808-b48a6386bb47/EasyAudioEncoder/Convert to WAV (to 8ch or less)/skc8r26mh2gx8hhh8f6mvdnt_11871-0-2.wav'
Jun 14, 2020 19:27:30.000 [0x7fb5537fe700] Fehler — [Transcoder] [eac3_eae @ 0x2a8ca80] error reading output
Jun 14, 2020 19:27:30.001 [0x7fb5537fe700] Fehler — [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 14, 2020 19:27:33.000 [0x7fb5537fe700] Fehler — [Transcoder] [eac3_eae @ 0x2a8ca80] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-9717be1a-5061-48f9-8808-b48a6386bb47/EasyAudioEncoder/Convert to WAV (to 8ch or less)/skc8r26mh2gx8hhh8f6mvdnt_11871-0-3.wav'
The “/tmp/pms*” folder will be createt by the pms service it selfe. Its randomized.
The problem seams to be that the server has not the rights to read in this folders.
ls -l in /tmp/…
drwxr-xr-x 3 plex plex    4096 Jun 14 19:27 pms-9717be1a-5061-48f9-8808-b48a6386bb47
And the user plex is nearly master on this system.
I know this issue since 1.19.2.* and most of the time a simple reinstall of the server was the solution. Until 1.19.4.… so i was staying on 1.19.3. but right now… the system iss blockt for any playback thats required audio transcode cause of the error in the rights system with folders that the server creats by him selfe!
Anybody any idea?!
The problem with this is usually because the inotify table is full (too many directories being monitored and the table fills. EAE requires 2 entries in the table to work properly.
The table size is easily adjusted when you know how many total directories are to be monitored…
When you restart, do you see PMS report “[Notify]: No space left on device” ?
If you have this error then:
Solved!!! You made my day!!!
Thats exactly the point and the solution… extamd the the inotify table and done…
BIG THX!!
