i can switch my lights manually - so bridge to plugin connection works fine - but its not listen to events. It seems that its not connecting, but i canât find the problem.
this is âtail -fâ of the log after i´ve restarted plugin. Any suggestions what i should try? thx in advance.
2015-12-12 16:22:30,563 (7faf97edb700) : INFO (init:451) - Adding room 1 to rooms âŚ
2015-12-12 16:22:30,565 (7faf97edb700) : INFO (init:451) - skipping room 2.
2015-12-12 16:22:30,567 (7faf97edb700) : INFO (init:451) - skipping room 3.
2015-12-12 16:22:30,569 (7faf97edb700) : INFO (init:451) - skipping room 4.
2015-12-12 16:22:30,570 (7faf97edb700) : INFO (init:451) - skipping room 5.
2015-12-12 16:22:30,571 (7faf97edb700) : INFO (init:450) - Room check done
2015-12-12 16:22:30,573 (7faf97edb700) : INFO (init:451) - [{âtransition_resumedâ: â400 msâ, âusersâ: [âaTVâ, âdaensch2kâ], âdarkâ: False, âluxlightsâ: , âtransition_pausedâ: â400 msâ, âmin_durationâ: â1 minuteâ, âpausedâ: âTurn Onâ, âlightsâ: [âFensterâ, âIrisâ], âclientâ: âaTVâ, âstoppedâ: âPreset 1â, âtransition_stoppedâ: â400 msâ, âdimâ: â20â, âtransition_startâ: â400 msâ, âonofflightsâ: , ârandomizeâ: True, âplayingâ: âDimâ, âroomâ: 1}]
2015-12-12 16:22:30,575 (7faf97edb700) : INFO (init:287) - -Getting available lights
2015-12-12 16:22:30,602 (7faf97edb700) : INFO (init:289) - Available lights: [<phue.Light object âIrisâ at 0x3d24fd0>, <phue.Light object âFensterâ at 0x3d24e90>]
2015-12-12 16:22:30,603 (7faf97edb700) : INFO (init:290) - Configured lights: [âFensterâ, âIrisâ]
2015-12-12 16:22:30,603 (7faf97edb700) : INFO (init:291) - Configured color lights: [âFensterâ, âIrisâ]
2015-12-12 16:22:30,604 (7faf97edb700) : INFO (init:292) - Configured lux lights:
2015-12-12 16:22:30,605 (7faf97edb700) : INFO (init:293) - Configured on/off lights:
2015-12-12 16:22:30,607 (7faf97edb700) : INFO (init:458) - Initiating current status, lights initial states and durations for active rooms
2015-12-12 16:22:30,608 (7faf97edb700) : INFO (init:468) - {âaTV1â: ââ}
2015-12-12 16:22:30,609 (7faf97edb700) : INFO (init:469) - {âaTV1â: ââ}
2015-12-12 16:22:30,611 (7faf97edb700) : INFO (init:366) - Initializing Plex class
2015-12-12 16:22:30,612 (7faf97edb700) : INFO (init:367) - -Getting Token
2015-12-12 16:22:30,613 (7faf97edb700) : INFO (init:378) - Token retrieved from Dict
2015-12-12 16:22:30,615 (7faf97edb700) : INFO (init:219) - Classes initiated
2015-12-12 16:22:30,617 (7faf97edb700) : INFO (init:221) - Closing daemonâŚ
2015-12-12 16:22:30,619 (7faf97edb700) : INFO (init:224) - Starting daemonâŚ
2015-12-12 16:22:30,624 (7faf97edb700) : INFO (init:226) - [<_MainThread(MainThread, started 140392346822400)>, <Thread(_start, started 140392228869888)>, <Thread(_start, started 140392212084480)>, <Thread(_start, started 140392220477184)>, <Thread(start, started 140392161728256)>, <Thread(_handle_request, started 140392144942848)>, <Thread(_start, started 140392170120960)>, <Thread(_start, started 140392178513664)>, <Thread(_start, started 140392186906368)>, <Thread(_start, started 140392203691776)>, <Thread(_start, started 140392195299072)>, <Thread(thread_websocket, started 140392153335552)>]
2015-12-12 16:22:30,626 (7faf97edb700) : WARNING (runtime:1065) - Generating a callback path for a function with no route: <function DisableHelloHueCallback at 0x2f86a28>
2015-12-12 16:22:30,630 (7faf986dc700) : INFO (init:599) - Starting websocket listener
2015-12-12 16:22:30,631 (7faf986dc700) : INFO (init:602) - Up and running, listening
2015-12-12 16:22:30,642 (7faf97edb700) : DEBUG (runtime:106) - Sending packed state data (109 bytes)
2015-12-12 16:22:30,650 (7faf97edb700) : DEBUG (runtime:924) - Response: [200] MediaContainer, 1139 bytes
Using Plex Version 0.9.12.19 on a OpenMediaVault Debian Server
BTW: Great work
