Photos moved to new location - not found [SOLVED]
Server Version#: 4.147.1
Hi there all.
Approx 3000 jpg’s that were previously found and catalogued and displayed correctly by PMS, were moved to another location on same PC.
After updating the path in the library settings, PMS only displays about 50% of the available folders thumbnails, and none of the thumbnails for the photos inside the folders that do not have a thumbnail.
However, the photos inside the folders are shown if I click the play button for that folder, or if I open a folder and select an individual photo.
A box/outline is shown in the UI for each folder, with the same name of the folder as that in which the files are stored, but with no folder thumbnail, just a blank frame and when opened, there is again no thumbnail inside those folders for the photos stored in that folder.
But as I say, the photos are there if you select in individual photo or click the play (slideshow) button.
DB issue perhaps or ?
ideas anyone?
cheers CD
Answer my own Q.
used the command line [ - - generate - - section ] for the corresponding photos library.
It took a long time for 3000 jpg’s (like 3 hours) but it did create a thumbnail for all photos and selected a jpg from a folder to be the thumbnail for that year’s folder.
