Physically moved server location, remote access working, is it secure?
So I moved my plex server to another physical location that’s behind a SonicWALL firewall attached to a comcast modem.
Remote access is enabled and working but only when I deselect “Manually specify public port”. The public IP in the blacked out section has xxx.xxx.xxx.xxx : 0 as the connection that’s working.
Is that ok and secure to run it like this? If I manually specify a port, remote access doesn’t work (I assume cause the modem and firewall aren’t configured to forward traffic to the plex server)
Manually specifying a port is only for when you have already set up a custom port forwarding rule with the chosen port. So if you didn’t actually set one then it will fail.
With that field empty the server will request a port to use from the routers UPnP system, which will be a random port the router chooses.
