Rasplex 0.1.38
I have a my Rasplex Pi hitched up to my 2012 Panasonic Viera and everything works beautifully (well, it's a little juddery in the UI but it's only recently been put together). It's powered off the TV USB socket - lovely - and CEC works nicely too.
One thing though: I put the TV on standby and, after a handful of hours, the Pi turns the TV back on, switched to the Rasplex input. By itself!
What is going on? Anyone any ideas?
Mine does this when I turn on my pi, so have you thought about turning your pi off? Weird it does it after a few hours though
Yeah, I should have mentioned that this happens when I turn the Pi off as well.
This is probably related to your TV.
Maybe it'll turn on the USB port while the TV is still in standby. The Pi will start if it gets some power via USB which will wake your TV afterwards...
Oddly enough it appears to be related to the USB port that I use on the TV. The third one does not cause this to happen.
Simon.
