LG TV Turns on from Standby with RasPi attached?
Wonder if any else has seen this???
The Pi is powered by its own power supply, i.e. 'not' by usb port on the TV. The Pi is connected to the TV via the HDMI cable (obviously  :rolleyes: ).
When I turn my TV off, I come back after a few minutes to find it on again  :wacko:
I do leave the Pi on, just because its easier (or because I haven't found a good way to turn it off/on when needed/not needed).
Any thoughts or suggestions would be greatly welcomed!
Adam
That’s a bug in the latest 9.20-release - it will be fixed in the next release, for now you can only power off the pi or disable cec.
Gesendet von meinem Nexus 4 mit Tapatalk
Thanks for the info :)
https://github.com/RasPlex/RasPlex/issues/134
I have the feeling that this bug is still in version 0.40. Am I the only one?
 +1
Problem still here
there is a bug report
https://github.com/RasPlex/RasPlex/issues/167
+1 defo still there as per my thread on 0.4.0 however also finding a problem in shutting the pi down too.
i found the shutdown issue and it will be fixed.
As per the shutdown behaviour when shutting down TV, CEC config needs to be set up properly, either to ignore or to poweroff.
Check Preferences > System > Input devices > Peripherals > CEC Adapter.
In there you should adjust the behaviours you want and NOT use Standby as the Rpi hardware doesnt support it :)
