Apologies to create a new topic.
Is there any update on support Plexamp on for Pi Zero?
Currently when attempting to run node a Illegal instruction message is logged:
mt@raspberrypi:~/Downloads/plexamp $ uname -m
armv6l
mt@raspberrypi:~/Downloads/plexamp $ node --version
v16.3.0
mt@raspberrypi:~/Downloads/plexamp $ node ./js/index.js
Illegal instruction
What is the possibility of getting a PlexAmp version on raspberry pi zero?
I thought of a project to build a Plexamp speaker using a headless raspberry pi zero with an audio hat and small amplifier all built into one box running of a single power adapter.
As I was testing out Plexamp on the raspberry pi, I came to realize the PiZero wouldn’t run it as the version of NodeJS used isn’t compatible with the ARM Processor on the PiZero. So I used a Raspberry Pi 3b+. The 3B+ is a little overkill for…
elan
March 30, 2023, 2:31am
2
i’m sorry, but armv6 isn’t supported.
Righto. Too bad. So no plans to support?
Ah have just realised the release notes do mention:
64-bit capable Raspberry Pi
Many thanks
elan
March 30, 2023, 3:43am
4
32-bit works fine, we support ARMv7 and ARMv8, but no plans to support down from there as there are performance and other challenges.
Now that the R-Pi zero 2 is out I was planning to try and use that. It has the same processor as the R-Pi 3 which is what I used on this original project.
In theory I should just be able to swap the SD card to the pi zero 2.
Although the last time I updated the R-Pi 3 inside that headless speaker it seemed to break something.
