PKC running on Eminence skin does nothing
I installed this got it synced but now no matter what I click on it does nothing. I dont understand what to do. I click on anything and it will say busy but then nothing happens.
Did you restart Kodi?
Make sure you selected “Addon Paths” in the PKC settings under Sync, “Playback Mode”. If you change or changed that setting, you need to resync: under Advanced, hit “Reset the Kodi database…” (in red), then YES, NO
@moviejunkie76 did it work?
