Play and sync unusable on Fiio X7 Hifi player !!
Hi
I own a Fiio X7 hifi music player running Android 5.1.1 on which I installed Plex as I want to listen to my FLAC music on it and also sync some playlists !
The sync is horribly slow (it synchronises 3/4 tracks per hour…) unless I have requested sync at original resolution so normally it should just be a question to transfer files no ? Sync with my other android devices and that same PMS works fine !
Each time I try to play a flac file in Plex App, it looks like it’s going to play it, but counter stays stuck at 0 and after few seconds a little message appears stating that player has crashed and it’s restarted but nothing else happens :frowning:
That device has two mode: regular android and Hifi android mode and it’s exactly the same in both !!
Vincèn
