Could you tell me if there’s a shortcut for that function or if it’s mapped automatically to a specific remote key?
If it does what I hope it does, this is the biggest change to PHT I’ve been waiting for.
I’ll have to test it but it really got me excited. I’ll use OpenHT from now on and will make sure to report any bug I find.
B.
It’s on the context menu, select a video, then press your ‘Context’ key to bring up the menu, then select ‘Play from Here’.
Oh boy, it worked exactly as I hoped. I’ve been waiting for this simple feature for so long. Thank you guys so much!
Another question then since I find popups (the context menu) annoying, I’m wondering if I could write a macro to do this for me or if there is way to associate a shortcut to that command.
On top of that, once I’m on a video, could it be possible to add an icon under the play one to do just that too?
In any case, thank you for your work and for the fast answer.
@Airchtit said:
I wouldn’t mind getting an answer to the original question though: Is there a shortcut or could there be a new icon for that functionality?
There is no ‘shortcut’, there will be no ‘new icon’.
