Play State not syncing
Recently Plex has stopped marking things as watched or keeping track of my progress through something if I stop it partway through. Everything remains as unwatched regardless of whether I watch all or part of it. I can manually mark things as watched or unwatched.
I notice in my "Plex Media Server.log" log that the following message appears every ten seconds:
Dec 15, 2014 22:07:07 [0x7eff1cff9700] DEBUG - Request: GET /:/timeline?containerKey=%2fplayQueues%2f&duration=2481600&guid=com.plexapp.agents.none%3a%2f%2f6b2234dff9acb95702e778a9d9e5695538ff338e%3flang%3dxn&key=%2flibrary%2fmetadata%2f31748&playQueueItemID=31748&playQueueVersion&ratingKey=31748&state=playing&time=1921919&X-Plex-Token=omidzD7iJgBV3v78Xjkh [127.0.0.1:53832] (1 live)
Dec 15, 2014 22:07:07 [0x7eff1cff9700] DEBUG -  * containerKey => /playQueues/
Dec 15, 2014 22:07:07 [0x7eff1cff9700] DEBUG -  * duration => 2481600
Dec 15, 2014 22:07:07 [0x7eff1cff9700] DEBUG -  * guid => com.plexapp.agents.none://6b2234dff9acb95702e778a9d9e5695538ff338e?lang=xn
Dec 15, 2014 22:07:07 [0x7eff1cff9700] DEBUG -  * key => /library/metadata/31748
Dec 15, 2014 22:07:07 [0x7eff1cff9700] DEBUG -  * playQueueItemID => 31748
Dec 15, 2014 22:07:07 [0x7eff1cff9700] ERROR - Had trouble breaking playQueueVersion
Dec 15, 2014 22:07:07 [0x7eff1cff9700] ERROR - ERROR: Parsing request failed.
I believe this is the message sent by the client to the server to update the progress through the file. It appears that playQueueVersion is not being set to a value as it should be, so the request is failing and therefore the play state is not updated.
I have tried deleting the ~/.plexht/ directory and starting from scratch, but the problem persists.
I can provide more logs if it helps, but they're all pretty much the same thing with different time= values.
Has anyone else encountered this? Does anyone know how to fix it?
Thanks.
To clarify, this problem was occurring with 1.3.2; I subsequently updated to 1.3.3 and 1.3.4 and was unable to play anything at all (much like others have mentioned in other threads).
In the end I downgraded to 1.3.0 using the plexhometheater_1.3.0.404-201411211132-ubuntu63~ubuntu14.04.1_amd64.deb I had lying around in /var/cache/apt/archives and this solved the problem.
When I get some time I might sit down to try and work out what broke it…
Same here ... running on Ubuntu 14.04 (Linux htpc 3.13.0-44-generic #73-Ubuntu SMP Tue Dec 16 00:22:43 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux), media server Version 0.9.8.18 and plexhometheater 1.3.5.431-20
Does anybody have a clue on how to workaround this issue?
