Playback Error 4294967279
Starting a few days ago I have been unable to play any media from outside my local network. Within the LAN I can play on any device/player without any issues. However from outside my network, I am getting an Error code 4294967279. I have tried connecting via the windows media player, via the web using app.plex.tv as well as directly to the external IP address - in every instance nothing will play. I can browse just fine, but when I go to play it spins for a minute or so and then gives the following error: “An unknown error occurred (4294967279)”
I have tried uninstalling and reinstalling Plex on my Synology as well and that made no difference.
Attached are the logs - any assistance would be greatly appreciated.
Server Version#: 1.22.3.4523
Player Version#: (PC) 1.31.1.2262-74fdc6b7
Player Version#: (Web) 4.56.4
Plex Media Server Logs_2021-05-14_15-58-46.zip (3.1 MB)
Check the space left on your DS918+.
There are 957 “no space left on device” messages in the log files.
May 14, 2021 15:54:36.660 [0x7f7c9c671700] ERROR - [Notify] Failed to add watch for "/volume1/Videos/TV Shows/Bar Rescue/Season 02" (28: No space left on device)
The transcoder is also logging errors that it cannot access the tmp_transcoding directory. This can happen when a volume is full.
Make sure you have adequate space left on your NAS.
May 14, 2021 12:53:31.005 [0x7f5b7bd11700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
May 14, 2021 12:53:33.000 [0x7f5bdd99a700] ERROR - [Transcoder] [eac3_eae @ 0xb26a80] EAE timeout! EAE not running, or wrong folder? Could not read '/volume1/Plex/tmp_transcoding/pms-c2379aeb-ebee-4ffd-8c61-db91f7bc47e9/EasyAudioEncoder/Convert to WAV (to 8ch or less)/a18a6a69-b689-4caf-aaed-fde556058788_23833-0-1228.wav'
May 14, 2021 12:53:33.002 [0x7f5b71c26700] ERROR - [Transcoder] [eac3_eae @ 0xb26a80] error reading output
May 14, 2021 12:53:33.002 [0x7f5b79fc5700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
If I may augment here?
When one sees the No Space message, it’s natural to think of HDD space.
In this case, because it’s got [Notify] in the error message AND because it’s listed with a whole bunch of other folders,
This is what it looks like when the Notification table fills up.
Resolution is simple, as Trumpy shows.
Thanks for the clarification.
Thanks everyone. It’s definitely not a storage limitation, still plenty of room.
And thanks @trumpy81, I’ll give those two fixes a try tonight and see if it resolves the issues.
@trumpy81, one quick question. I found the steps to change the folder locations, but just wanted to double check that the scanning of the library won’t try and redownload all the metadata, posters, etc.
  • Disable auto-empty trash
  • Stop PMS
  • Move or copy the files
  • Start PMS
  • Add new path(s) to library in addition to the old path(s)
  • Scan library
  • Remove old path(s)
@jlongiaru
Are you trying to correct the Notify table overflow (for playback)
-or-
Move media
Thank you very much!
