Server Version#: 1.21.3.4021
I am having some issues with PMS running on an Unraid docker. I can be playing a TV program and suddenly the playback stops (the buffering in the payback progress disappears) and the program stops with just the spinner showing. I have tried to leave it and it can sit there for hours and if I try to playback something else then that will not start either and basically I have to restart the PMS before I can get any playback again.
If I play directly from a SMB share to VLC then I have no issues, but that really defeats the purpose of having a PMS.
I am running Plex on an Docker image through Unraid on a Dual CPU Intel 2680v4 with 256GB memory with a Quadro P2000 but as it is on my local network I assume is is playing directly.
I can’t pinpoint the reason why so need some expert help. Thanks in advance.
I have attached the logs and the issue occurred at 13:21 to 13:23 roughly when I clear the logs to test again.
