"Playback has stopped due to multiple playback errors"
Server Version#: 4.22.2 Linux Ubuntu 16.04.6 LTS 64-bitPlex Media Server Logs_2020-02-25_00-13-37.zip (4.5 MB)
Hey y’all!
So, I’ve had this issue for a while and I’m finally trying to do something about it. Hope the forum can help. As the title says, I get this error only sometimes when playing videos with Plex. This is the message that appears on my Roku Ultra, and also my sister’s Roku Express: “Playback has stopped due to multiple playback errors. Please check your connection and try again”. On the web player there is no such error message, but I can confirm that the same video will not play there either. On the web player there is just a spinning status wheel type thing. I haven’t bothered until now to seek out the issue as a restart of the Plex Media Server will always fix the issue. I’m tired of having to do that though, and I don’t want my users having to text me whenever it happens to them. I had it happen just now with a few videos and I’ve downloaded the logs and uploaded them here. If anyone out there has experience with this issue and can see what the problem may be from the log files, I’d greatly appreciate any advice. Thanks in advance, and please, if there is any other useful info I can provide, let me know! Cheers!
You have networking errors.
Feb 24, 2020 23:41:53.474 [0x7fe0b6ffd700] DEBUG - HTTP requesting GET http://192.168.50.1:49152/wps_device.xml
Feb 24, 2020 23:41:54.502 [0x7fe0b6ffd700] ERROR - Error issuing curl_easy_perform(handle): 7
Feb 24, 2020 23:41:54.502 [0x7fe0b6ffd700] WARN - HTTP error requesting GET http://192.168.50.1:49152/wps_device.xml (0, No error) (Failed to connect to 192.168.50.1 port 49152: Network is unreachable)
Feb 24, 2020 23:41:54.502 [0x7fe0b6ffd700] ERROR - SSDP: Error parsing device schema for http://192.168.50.1:49152/wps_device.xml
Feb 24, 2020 23:42:00.056 [0x7fe122611700] DEBUG - Auth: authenticated user 17425582 as Evan
Feb 24, 2020 23:42:00.057 [0x7fe0957fa700] DEBUG - Request: [192.168.1.46:35643 (Subnet)] GET /:/timeline
One moment the network is there and the next it’s not.
If the server is on WiFi (always a bad idea) wire it to the LAN.
@ChuckPa That’s good to know, but I’m not sure it’s the problem. I tested a few videos when this was happening, and some played and some didn’t. The ones that didn’t play failed every time and the others played fine every time. If it’s the network cutting out it’d have to be a crazy coincidence that it cuts out every time just for the videos that have failed previously. Also restarting the server fixes the problem immediately every time. I have a wired connection to the server BTW. Any other ideas?
Anyone else out there have a different theory or solution based on the log files provided? This issue is getting real annoying.
I haven’t had the problem with my Roku but several i share my library with do. Looks like i’m going to have to go back to a previous version of Plex to fix.
I have recently had this similar playback issue on all of my plex devices from the Ubuntu Plex server(s) to Roku Plex App. I do not see bandwidth issue but do see spikes of upward to 80Mbps. I also see CPU on server max out (8 core). When I play same movie on Amazon Firestick, Local PC, or phone app, I do not see issue with streaming. This (to me suggests transcoding issue and perhaps Roku has made a change to which CODECS they support. Perhaps Plex App on Roku has made a change?
I ended up so frustrated by this issue that I just completely wiped my machine, reinstalled Ubuntu 16.04 and completely rebuilt my server. I’m running a fresh install of Plex that’s updated to the newest version and thankfully all that seems to have eliminated the problem. Not a fun solution, but it’s the only solution I found. There are so many other users who have had this issue, you can Google and read forum posts for days without finding any useful info. Too bad that Plex pass we paid for includes zero actual support. Now at least I have a working server again. I’m just bummed I lost all my watched status and collections because I was afraid to backup anything in case it carried this problem over. For what it’s worth, I don’t believe this to be a Roku problem. Whenever I saw this on my Roku, I could go to the web app on my server PC and try to play the same file, and it wouldn’t load. All of my files are converted to mp4 h264/aac audio so it’s not compatibility. There would just be that spinning circle in the middle of the screen. Good luck to anyone with this issue. It’s a bi@#h.
I took your advice and rebuilt 3 Plex Servers with Ubuntu 16. I had built them previously with Ubuntu 18 which worked great and suddenly went to #%^!.. With the rebuilds, I have distributed the load of movies among the different servers out of paranoia. It is now working with the key words ‘Ubuntu 16’. This issue has been driving me nuts but hopefully is now resolved. Good Luck to all.
I have this same issue with the newest Linux build. Ubuntu 64 bit. I had to revert to previous plex build and everything works now.
Yep, now that everything is working I’m terrified to ever update again, which sucks. It’d be cool if this server software was designed in a way that you don’t have to chose between new features and performance updates vs. completely breaking your $hit. :man_shrugging:
Is there an update on this issue? I am still having this issue!
Don’t hold your breath. Solution for me was to wipe my machine and start over.
Excuse me?
How does a LAN/host network issue mean the server is faulty?
I’m not grasping.
Also, regarding “Wipe the machine & start over” is like burning down the building because a room needs painting, isn’t it?
Backups of you entire metadata structure, in cause the host itself is compromised,
are easily done. Is assistance needed in this regard?
May I see some DEBUG, not VERBOSE, log file ZIPs which capture this issue?
Anyone found a fix for this yet? It’s been months. Every single video I have with AAC audio gets this error randomly, and it’s driving me insane.
On a Windows 10 machine. Roku does not play and Plex (web) does not play if the file has an MP4, codec but plays fine if it’ an H264. They all play fine on the stand-alone Plex app. Any ideas how to fix this?
Update MSMPEG4V3 files don’t work either.
